Fabricio Morato
anyone know where I am meant to send them to?
Open a ticket on the support page (red.com) and send the log there with the reported problem.
Anyone know if baked in color is working for Prores now and in what capacities?
Just upgraded but I can't get ANY baked in color in Prores to work.
Do we get baked in color on the prores files we shoot as Proxy files along with the R3d??
Curtis
Wooden Camera Cable-Less Gold Mount battery plate doesn't show voltage or percentage - this is a major problem... voltage I can live with, percentage would be incredible - no info - Perilous.
I installed the beta and ran a sensor calibration, which was successful. But now I occasionally get a little text box saying "Auto Calibration" on the bottom of the screen every now and then (maybe a few minutes apart between popping up). I did a full wipe of the camera and re-calibrated, and it still pops up. Is this a bug or is it something else I'm not realizing?
This is just informing you that the auto calibration is recalculating and applying. It is normal for this to occur somewhat frequently at boot as your camera comes up to operating temperature. This notification was added in 6.4 (that is, 6.3 just silently updated the calibration). During this process it is normal for the monitor feed to stall for a few frames and people were concerned something was wrong so we added the notification.
So Trent could this be why when shooting on 6.3.102 I have what seems to be the camera freezing frame for a brief second on the monitors, even though the camera is still recording or even when in standby and then the image continues like nothing happened? This occurs every now and then say you might see it after the camera is up and running only a couple times in 30 or so mins of operation? or is that probably something else?
Turning on record audio notifications often causes the record/power button to not function - only way to power down is removal of battery. This was intermittent but often - record would work a couple times after a reboot before freezing at best.
The touch controls would freeze after rec pressed although picture would still be live.
Turning off audio record notifications everything worked normally.
Auto calibration is not updated while recording, only during what we call preview (standby). If you are seeing the monitors freeze while record is active it might be something else - you may want to file a support ticket just to make sure there isn't a problem. Support will want to know what kinds of monitors you are using, power source, etc. If you can catch the problem on video that would be helpful for them as well.
I'm assuming you don't see any problems in the recording when this occurs?
