Joe Kocsis
- Feb 10, 2009
- Burbank, CA
- www.nooneuknow.com
When running out of the rocket and into AJA hi53g into a Dreamcolor monitor I'm experiencing flicker in the very low blacks. It's not noticeable on well lit scenes, however in low lit scenes it can be very distracting. I've also hooked the dreamcolor to a MXO2 and when using the calibration tool only a a very specific black level do I see flicker. 1 tick higher no flicker, 1 tick lower no flicker. I've recalibrated the monitor and still see the problem. I only see this when the Hardware Engine is active (ie: sending an RGB progressive signal to the dreamcolor.) If I send a YUV signal and the Hardware Engine is disable I do not see the problem.
Wondering if anyone has experienced anything like this?
Thanks,
Joe
Thanks,
Joe
