Brandon J.F.
- Sep 12, 2010
Figured it out. The Sequence settings where right, but it turns out I had to interpret the footage from 30fps to 23.976. Is there away to have RedCine tag the TIFF sequence as 23.976 when you export?
No, you have to manually set the frame rate after you import any image sequence. It would be nice if you could change the default from 30 to what you generally use.
