DPX output problem in REDCINE
dgm204
Hello,
Ive made a telecine XML in crimson and taken it back into REDCINE. The media all loads fine... everything is good... but when I try to export DPX files I only get a single DPX file.
It processes through every frame of the video in REDCINE but only one DPX file comes out for each shot.
I've had it work at times, and I get a proper DPX file sequence... but rarely...
In fact it seems that if i do just a one shot xml i get a proper DPX sequence, but multiple shots seem to bug out...
any ideas?
by the way Im using for filename EVENT#Z/#F#S.e as Crimson tells me to do... is this the problem? is it just rewriting over the same file?
MUCH APPRECIATED
DAN
