Does it fit?
bevan goldswain
A question for all the Movi M15 users out there who use the Freefly Vlock adaptor to side mount a Vlock on the dragon.
What is the biggest battery that will fit?
Does the new IDX DOU 95 fit?
Or the Switronix Hypocore 98 ?
Anyone know?
I've only ever had the tiny IDX E7s, but the amount of space on the sides is still quite a bit. I did have an instance of mounting a RED Brick on the side of a Carbon Dragon on the M10. A little different center of gravity because of the Carbon body, but it was still possible.
If anyone has solid info about the Hypercore 98's I would like to know, as I've been eying those as my next set.
The hypercores seem to be the same width as a REDBRICK, if you say a redbrick actually fits then a hypercore should fit too.
How much space did you have left when you used the Redbrick?
And Austin, do you know if there is more space (on the sides of the camera) with the Movi M15. - I actually have an m15 and an m10 but both are away on long shoots so I wont be able to test for a while but really want to buy some batteries.
