Steve Freebairn
I'm looking at building an Intel based PC server with an Areca 24 port Sata II raid 6 card. I know the card will handle the formats I'd like to do, my real question is how I can allow others (3 other computers) access to the speed of the drive. I know that iScsi is an option.
Does anyone have any experience using multiple NICs with iScsi?
Another option is to use a quad 4gb fibre channel card and then put fibre channel cards in each system.
My main question with this approach is how much speed will we lose? The Raid card is capable of 1600+ megabytes/sec, will 3 users be able to get about 300 mb/sec each using 4gb fibre chanel?
I know that 4gb fibre is capable of 400 or 500 megabytes/sec depending on whether it is 10bits/byte or 8 (see Sata2 if you have questions about this, 3gb/sec means 300 megabytes in that case). So I assume that a quad
4gb/channel card would be capable of feeding up to 4 users 300-400 mb/sec.
So, does anyone know if my assumption is right? If I'm only using my server as a "raid box" how fast can the data be passed from the raid card to the fibre channel network (or iScsi if that would work)? Any help or thoughts would be appreciated!
Ideally we'd all have enough for the camera and several hundred thousand for accessories, but in this case, we don't. The server will be used for working storage and we'll be using a tape backup drive to archive projects.
