Dimensions of Red primes?
Innerspace is amazing, they can custom design any case for you. (number of latches, handles, color, type of foam etc.)
So they already have correct dimensions? I should be able to call them and get a 6 lens case?
They most likely can build you anything you want or need... that's what they do. The RED cases have some special proprietary features and design that are only available through RED, but if you want just a standard case with the proper cut outs they are more than capable of helping you out.
Jarred,
You should consider a case that holds the 6 Primes (including the awol 18mm) instead of the 300mm. You dont typically haul around the 300 with your primes. I prefer keeping the 300mm in its own case.
Totally agree.
Also the case needs to be made of lighter weight material, no more than 20Lbs. Otherwise with 6 4Lb lenses you'll be over weight for airline check.
Jarred,
The 18mm will go in any hole.. The 300mm will go in any hole.. the primes will go in any hole.. you just choose the insert that fits your lens... It is a somewhat modular design.
Jarred,
Yep, a six lens case that holds the 18mm instead of the 300 would work best for me too.
