Difference between M and X EPICS???
Jean Guerra
Dominican Republic, Santo Domingo
i want to know if there is going to be a big difference between M and X EPICS....??? i recently bought an M epic , its on its way....but soon i will need another camera....i want to know if there is going to be a significant difference for the X epic....should i wait for the X or not??? is it going to be the same as M???
thanks
attachment.php
I believe this is correct based on recent announcements and pricing. As always...change is inevitable.
If you are needing another camera "soon" as in a week or two, then Epic-M may be the way to go., in my opinion.
If you are needing another camera "soon" as in sometime late summer early fall, then waiting for Epic-X becomes an option.
And of course, that definition of "need" is as in "cannot do without" not "would like to have".
So much is relative, you know!
attachment.php
I believe this is correct based on recent announcements and pricing. As always...change is inevitable.!
it's not quite that simple. If you are comparing it to Stage4 EPIC, the M's are $58,000 for what will be $49,000 (when you factor in all of the included pieces), I believe.
Even if you were to buy the Stage4 Brain only, it is now $29,500 due to the new standard titanium mount.
If you think you can make $9,000 in the next 2 or 3 months, I don't see why you wouldn't get an M if you are also wanting all of the bells and whistles which come standard with an M.
Thanks for checking that, Joseph. I was re-reading Jim's post and was updating the image as you posted. You are correct when factoring it all the extra accessories that come standard with EPIC-M, it's a $9,000.00 difference. The biggest advantage the M has, I think, is immediate availability.
