Dealing with RED MG 6K Legacy mode
Srdjan Sipka
Bosnia and Herzegovina / Banja Luka
www.mania.marketing
Since the IPP2 update i am having some troubles with LUT's on my RED Weapon MG 6K. Eather its a bug, or i don't understand how it works.
Because I am on Dragon sensor, I am stuck with Legacy mode. Once I set my gamma and color to REDWIDEGAMUTRGB and LOG3G10 as my base, i add a LUT on top of that and it works just fine. Having that big line in the corner irritates a bit but it is what it is. But once i go in to playback mode, I lose the LUT and all i see is raw flat image. So, while still in playback mode, i go in to monitoring and find LUT to add again, but its all grayed out, cant select anything. I tried this on my friends Epic W and it works good on his Helium.
Only solution i have is not to film in REDWGRGB and LOG3G10, but instead use lets say Gamma 4 and REDColor 4 or what ever. In Playback mode i will still lose my lut, but at least the image will not be flat.
Any solution for this?
Here are two pictures of my LUT setting in record mode and playback mode.
