Adam Johnson
So will this be able to fly a semi-rigged Red One? What will be the weight limits of the new design?
Thanks!
Adam
Thanks!
Adam
Is there any possibility of being able to test out this newly designed Laing Rig at NAB, would be a great opportunity for many Redusers who are going to be down there to get some hands on impressions.
Hi Vitaly,
This would be AMAZING! You would have lots of anxious Redusers ready to try it out, and at the very least a few of us could give our 2 cents![]()
Small update - http://www.nex-hack.info/wiki/laing-photos
Added photos of monitor mount that use 15mm rods.
And also prototype of bottom box with lemo connectors.
Why did you add two HD-SDI connectors? And is it still an open system? The d-box looks like it's closing the pole, making it impossible to add an HDMI or other cables without removing the box.
No one prevents you to use one of BNC connectors for other purposes, as connectors are widely available and very cheap, or use them for dual link interface.
Adding HDMI connector is also planned.
As for closed/open system. It is first prototype box and is optional item. You could remove it. And few other variants and designs are under review.
When does this groupbuy open/close, where do
we order? When are the modifications ready?
Would this model ultimately be modular with other industry standard components? So as we progress with its use, it would be possible to replace the vest, arm or sled? I think this is the case with the other group buy, but this is more in my credit card range at the moment. Cheers.
