Arnold F.
What would my "crop factor" be when using Pentax 67 lenses?
Arnold,
Not sure what you´re asking for. A lens does not have a crop factor. E.g. 50mm will always remain 50mm. You´ll have to consider that these MF lenses have been calculated for a much greater sensor size of 54x70mm and won´t be as sharp as dedicated cine or "FullFrame" DSLR lenses. They might look very nice though, as always depends on the project.
Cheers, Ulf
In Ulf's defense, I'm not sure I understand what you're asking for either, Arnold. Lenses don't have crop factors, but as these Pentax lenses are designed for Medium Format cameras, they will project a larger image circle than a lens designed for a 35mm camera. Generally speaking anyway, these lines really blur at longer focal lengths as longer lenses tend to project larger image circles.
So if you have a 75mm Pentax MF lens and put it on an EPIC, you're going to get the same angle of view that you would have if you put any other 75mm lens on the EPIC.
Now if you want to relate crop factors between the EPIC and a Pentax 67 series camera, that's another matter. It varies between the various models, but the maximum frame dimensions on the Pentax here are 70mm x 60mm. Maximum frame width on the EPIC Dragon is 30.7mm. So in landscape, the Pentax is 2.28X wider or the Dragon is a 0.44X crop of the Pentax 67.
Crop Factor is up to Sensor size not the lens focal lenght.
No doubt. I reckon I'll buy a 67 lens, put it on and try to figure out what the focal length looks like on the monitor.
Of course it is. I'm hoping that we can help people to see that by coming at it from the other direction.
I don't know. I think I've tried to explain it from every which way imaginable and it's like a lost cause much of the time. And we can blame a lot of the DSLR and consumer camera makers to. Their incessant desire to quote things in reference to crop factors or "equivalent" focal lengths in regards to 35mm FF systems is often infuriating and just a total dumbass way to go about this stuff. Now the entire industry tries to think in these terms and it just creates far more confusion than any form of actual understanding.
I hear you. IMO, the concept of "crop factor" has done more to stunt people's understanding of lenses than just about anything else I can think of. I grew up shooting 35mm, 6x6, 4x5, 16 & 35mm film, and oh yes, occasionally 8x10 and 35mm half-frame. It was never a problem to understand field of view equivalencies between any of those systems; all you really needed to know was what focal length gave you a "normal" field of view for the format.
But every once in a while I have to wade into one of these discussions just to see if I can slay a dragon or something...![]()
David,
Same here, coming from stills photography I´ve been using a variety of formats as well and feel familiar with the topic. I think the "problem" is the perceived conjunction of focal length and viewing angle which clearly does not exist. What´s actually surprising for me is that Scarlet / Epic users are being trapped as the use of the different resolutions is done by cropping the sensor size and should lead to a realistic approach to perception of focal lengths.
As nobody really came up with something new after my response and being flamed immediately can anybody shed some light on what might have been the question since the OP stated he is going to buy a Pentax lens to get his answer??
Cheers, Ulf
