Crazy EVF Idea!?
Technically (ignoring the issue that the current firmware does not support any of these following options), we should be able to support two RED-EVF's or two RED-LCD's instead of one RED-EVF and one RED-LCD. But the video feed to these ports comes from a common source, hence you can't have different video treatments going on, but instead two identical copies of the same thing. The displays themselves might have other options though - such as REC709 display v's Linear, or Color v's Monochrome.
Do you see any value in this for your applications?
Yes, I see quite a bit of value there. You could have a high contrast Monochrome version for seeing certain details while still having a normal image to look at.
Re: the video feed to the ports:
Any chance the LCD could be made to do 1:1 pixel scaling of the image on it's own, so you could have separate sizes for the focusing purposes mentioned above?
