[FS: OPTICS] Cooke Speed Panchro JDC Rehoused 7 lens Set, 18-100 plus case
Stephen_G
Banned
I am motivated to sell this set of lenses.
Sale Includes 7 lenses total:
18/2.3, 25/2.3, 32/2.3, 40/2.3, 50/2.3, 75/2.3, 100/2.8
ARRI style rear PL caps
ARRI style or machined front caps
Flight Case
New Custom Cut Foam for the lenses.
I have had each and every lens on a projector and the 40,50,75,100 will safely cover the Dragon 6K sensor!
the 18, 25, 32 should also cover but with heavy vignetting
all the lenses projected beautiful sharp images wide open.
these lenses have the best look on digital sensors
TLS serviced the mechanics of this set completely when I purchased them in MARCH OF 2014.
the threads were sprayed with emerlon and lapped, the focus action is smooth on all the lenses
the glass was cleaned
everything was adjusted to be in excellent collimation
the glass is coating matched and should color match excellent.
the 75mm has NO yellowing at all.
I am asking $40,000 or BEST OFFER. This is a bargain saying recently a 6 lens set went for this much.
Pictures below, full set plus the 18mm.
  • Thread starter
  • Banned
  • #2
25mm, 32mm
  • Thread starter
  • Banned
  • #3
40mm, 50mm
  • Thread starter
  • Banned
  • #4
75mm, 100mm
  • Thread starter
  • Banned
  • #5
100mm
  • Thread starter
  • Banned
  • #6
all the lenses have a 180 degree focus throw
they all have focus gears
the 75mm has a focus and iris gear
18mm T2.3 95mm front CF 8 inches
25mm T2.3 100mm front CF 1ft
32mm T2.3 80mm front CF 1ft
40mm T2.3 80mm front CF 2 ft
50mm T2.3 80mm front CF 2 ft
75mm T2.3 80mm front CF 2 ft
100mm T2.8 80mm front CF 4 ft
All the lenses focus beyond the last mark on the barrel.
TLS serviced the mechanics of this set completely when I purchased them.
When was that?
Also, when and by whom were they rehoused?
Nothing like the rehousing of TLS today.
They look quite used. Hve they been out on rentals since you purchased them?
If so, have they been serviced recently or will they be before the buyer takes receipt of them?
I have had each and every lens on a projector, they ALL will cover the Dragon 6K sensor!
I own a set of TLS rehoused Panchros and love them but the 18, 25 and 32 don't come close to cover 6K dragon they cover 5K HD just fine. Are you sure you interpreted the projection results correctly? Have you put them on a Dragon at 6K? Shoot a white wall wide open and post please.
they get out to the G box on the gecko projector. stopped down, the 18,25,32 will still vignette but should cover. I will revise my post
they were serviced by TLS in March of 2014
they have not been out since then
1 shot with the 18 at T2.2 minimum focus
1 shot with the 100 at T2.8
bump
bump I currently have an offer on the table, I am open to negotiations.
bump
bump
bump
bump
bump
bump
internal focus, small and compact, lightweight
bump for this set
bump
