Cooke Speed Pancho
Ben Steensels
Belgium
Don't know if this is the place to ask this question, but here it goes:
How much does a decent set of 6, rehoused by TLS, Cooke speed Panchro's go for?
18mm S3 T 2.3, 25mm S3 T 2.3, 32mm S2 T 2.3, 40mm S2 T 2.3, 50mm S3 T 2.3, 75mm S3 T 2.3
The TLS rehouse Pancho's are usually about 60-65k, the PS Technik's about 45-50k.
This may be a bit off topic, but due to the title I thought it could be a good place where someone with experience might chime in.
I'm looking to transition into a set of Cooke speed panchros and I want to know if folks who have used the TLS rehouse of the speed panchros have had any issues or troubles with the iris ring with FIZ units due to how close it is to the mount. Also, it seems as though the iris and focus rings are somewhat close as well. Any thoughts. I will be renting some soon, but will be doing Steadicam work where I'll need both wireless focus and iris.
Ok, look forward to any replies.
-Thanks in advance, Rafael
