Cooke Panchro S2 and S3 lenses Remount?
One word of caution: I had to have the mount itself sprayed inside for tighter tolerance and 2 lenses mounts shaved off ever so slightly to make a tight fit across all the lenses, since depending on use, each mounts tolerance will be a little bit different. Paul Duclos did a great job matching them all for a tight but smooth fit.
:biggrin: That took a little bit of elbow grease. My arm still hurts from lapping that pup. How is that working for you?
