Reuben Evans
This thread is blowing my mind. Maybe one day I'll ascend these heights, but you guys are awesome for having this discussion here for us to learn about the next level.
let the sides of the sensor go wherever they go BEYOND 24 mm, to a full 35.4 MP for an 8K size, that all.
Which I'm sure is possible but it may reduce your high-speed frame rate options.
David,
My preference would be to keep the sensor width the same at 8192 across, BUT regardless of aspect ratio, increase the height to around 18mm... Doing some quick math, 18mm tall gives a vertical resolution of 4,932
That's pretty damn close to 5K spec, so I'd then just recommend going for a 5120 vertical yielding a sensor height of 18.688mm.
Cleave out your 1.2:1 aspect ratio for your 6Kx5K Anamophic mode and crop vertically for all of the rest of the spherical modes.
That's my Win-Win dream right there!
I would assume that it's the total amount of data coming off of the sensor that affects the processing capabilities.
6k FF / 6144 x 3160 / 19.42MP = 82.806 fps
6K WS / 6144 x 2592 / 15.93MP = 100.67 fps
6K HD / 5568 x 3132 / 17.44MP = 83.331 fps
David,
