Converting 48fps footage to 24fps PP CS6
Abe Espinoza
OC, Ca
Hey! Was hoping someone here could instruct me on how to convert some interview footage that was shot at 29.97fps back to 24fps. I'm editing on a Mac/ Premiere Pro CS6. Timebase was set at 23.976.Thanks in advance!Abe Espinoza
The best way would probably be to have Premiere Pro reinterpret the footage as 29.97fps, then drop the footage into a 24fps timeline. To do this right click on the clip in your project panel, go to Modify > Interpret Footage. Then click "Assume this frame rate" and set it to 29.97. After that you should be all set to put the footage into a 24fps timeline.
Thanks for the response Tony. It is very much appreciated. I'll go ahead and try that out.
ABe Espinoza
