Ben Scott
- Mar 11, 2011
- London, UK
- www.smallrebellionfilms.com
My answer to everything
Having done a bunch of these, I'd agree with Ben, to a point...sometimes it goes really smoothly and easily...but then there are those lenses where the screws just won't come out, no matter what you try...that's where specialized tools and experience really come into play.
Hey David, I'd recommend having a 50mm, and a 135mm (both are relatively affordable, and very useful to have...especially a 50m).
Hope this helps.
I'd hope the Zoom would cover my needs for a 35mm and a 50mm, at least for now, I'll probably get them both later on. The thing is: I shot Super35 sensors about once a month or so, may it be Red, Alexa or Sony F's. And quite often Canon 5Ds and few times C300/100... but I'm about to purchase a BMCC (only one I can afford at the moment) and for it, a Speed Booster, making the 18mm=29mm, 25mm=40mm and so on, that's why I wasn't thinking about going over 85mm, but you're right, I shall look into a 135mm 2.8... but not sure about the 50mm at this point... well, I do use a 50mm a lot when I shoot with the 5D, but I'd use the 60mm Macro instead, at least for now, no?
Have you tried out the special anniversary lenses? 85mm 1.2, 55 1.2 and 135 2?
And yes, it's helping a lot!
Not sure if you can use a speedbooster with these. Is there a speedboster for EOS lenses on BMCC? I'm not uptodate on that. Maybe there is. I guess there is Contax to M43 speedbooster, so I suppose you can use those.
That's precisely why I wanted to switch mounts, there's no EOS to M43 adapter yet for some odd reason...
So you don't think the 60mm replaces te 50mm? Because of weight?
I've found it really hit and miss trying to remove the mounts for Leitax conversion. Once the screws are out it is easy.
I had to take three lenses to a specialist who for some reason drilled out both the screws and the threads! Needless to say it was difficult to get the eos mount on securely. David was able to send me some slightly longer screws which rectified the situation, but I had some nervous days with useless lenses.
Yeah that's why I had Peter at RP lens do mine. Didn't want to deal with the hassle of dissembling the backs of all my lenses!
I'm going to have to send him a pelican case full of lenses sooner or later to get cinemodded.
Hey guys, so was playing with the 100-300 last night...and WOW...I realized something...important. The close-focusing on this lens is SICK!!!! As opposed to most 300mm's that can't focus any closer than 10 feet (the 300 f4 min focus is 3.5m...which is 11.5 feet...for ex)..this bad boy has a min focus of 1.5 meters!!!!! Which is 4 feet 11 inches!!! It's a shallow depth of field monster!!!
I was mucking about last night and realized I wasn't across the living room focusing (as I am normally with 300's)
Instead I was almost on top of my test subjects...which on a 300mm is bonkers.
Put it this way. The 180 2.8 has a floating element to help it with close focusing, and IT focuses at 1.5 meters. This bad boy focuses just as close...but at 300mm!!!!
does everyone have a contax set already? i've been trying to sell mine for months.... if anyone's interested...
http://www.flickr.com/photos/24159250@N08/sets/72157635402476250/
