Connect to Steadicam pilot
Sverker Hahn
75
Leksand, Sweden
What cable am I to use with Pilot?
I have the DSMC2 V-Lock I/O Expander.
The Pilot has a RCA-connection, I suppose the signal from Raven should go there.
But which on the Expander shall I use?
DC IN (6-Pin 1B LEMO socket)
3G-SDI output (75 Ω BNC), 60 Hz max frame rate
HDMI 1.2 output (Type A socket), 60 Hz max frame rate
SYNC (Genlock IN / Timecode IN / Sync IN) (4-Pin 00B LEMO socket)
CTRL (Tally OUT / RS-232 Rx and Tx) (4-Pin 00B LEMO socket)
USB Power output (Type A socket), 1.5A
P-Tap Aux Power output (2-Pin), 3.0A
Stereo Analog Microphone input (3.5mm jack)
Stereo Headphone output (3.5mm jack)
No RCA output as far as I can see.
I would appreciate any help.
(Tech has moved forward with all the gimbals out there, but I really should be getting along with the Pilot.
I have had it for several years, but I have never been friends with it. Now it is the last try ...)
