Stefan Engelhardt
New member
- May 14, 2010
Occasionally I'm getting different results out of the Rocket Card after I reboot my Mac Pro. I'll process some rushes and then have to reboot for some reason and when I do the same rushes again with the same settings they look different.
I've done tests and it only affects the Rocket Card. If I go through the same process using software only there is no difference in the footage after the reboot. Also, the problem seems to occur more on some people's users. The Rocket Card was installed under admin and everybody is using the same version of RedCine X, so I'm wondering if there is something else that could be missing from some people's users that could be causing this?
I've attached an image to demonstrate the difference. Its probably most obvious on the histogram.
My specs are as follows:
Mac Pro running Mac OSX 10.6.2
Dual 2.26 GHz Quad-Core Intel Xeon
16GB Memory 1066 MHz DDR3
