Petros Nousias
- Jan 4, 2007
The reason I was going for the eizo instead of the cinemadisplay is because ive read that its far more accurate. Any thoughts on that?
I think the problem with ICC profiles is that the LUTs are all in LAB space, and that LAB is too computationally expensive for video work.ICC profiles would be useful for that second problem, though, the mapping of that X'Y'Z' space to the display device. It would be been nice to have a standard approach to this based on a widely deployed technology, instead of leaving the whole thing up to device makers.
RSR is definitely more reasonable... and it's quite a flexible product (though I'm not sure if it works with NLE's... I'm in contact with them now about that).
Still, though, by the time you purchase a probe and the necessary components, I've paid twice as much to calibrate my display as I have for the NLE suite itself...
Am I asking too much for this to be part of an NLE? Or, at least, for software that's in the hundreds per seat, instead of thousands?
I think Chris nailed the crux of the biscuit with his analogy to desktop publishing and the concept of barriers being broken from the bottom up. The devotion to established color management strategies might persist in the high end of the market but beyond that forget it. IMHO tape to tape color correction will go the way of the dodo.
Properly set up rooms operated by talented specialists for top quality audio mixing and color grading will still have a place anytime there is a bit of budget and/or quick turnarounds. The real sea change here is that with the maturation of the commodity NLEs (particularly Final Cut) you'll get the ability to get very close to the same finish quality.
We need robust file formats that support higher bit depths and are easily interchangeable. The RedOne > RedCine data centric approach may not be fully supported on day one but given time I expect it to be a very smooth ride into NLEs that are ever more fully featured.
For my part I have painted the walls 18% gray, added some medium gray acoustical panels, spent a little coin on some near field optimized speakers for audio mixing and am ordering an eCinema DCM23 monitor for color grading. I may not be able to match the talent of the best post houses in LA or NY but if Final Cut Studio 6 includes a 10 bit color correction engine...
... and the walls came down, all the way to...
My goals are Broadcast, Blu Ray and Internet. When I shoot 4K it will be downrezzed to 2K or 1080p for everything.
