Color curve control by number
King Cheung
Dear All,
I am new to Color. When I was using Avid to tune color, I can type the numbers in boxes to tell the value of input and output in order to fine-tune the curve control. Does Color have the same effect -- letting us to type numbers to set the value instead of using a mouse to move that thoes lines, which are reliable and detailed enough for fine work.
Thank you very much.
the numbered values are on the right side under your color/matte isolation controls. the increments are a lot finer than in Avid though, so try increasing and decreasing increments in the decimals first, full number increments give you very dramatic results.
