Grayson Austin
- Apr 11, 2012
Cmotion Cvolution Wireless Lens Control System with Arri White Radio modules for sale:
*Two new/unused Cvolution Arri white radio (handsets can talk to any Arri camera with the white radio installed without an MDR) main handsets both with external antenna connectors (change antennas for different situations). These main handset units are identical. Neither one is a "junior" type handset like the Preston. It is identical to Handset #1 in its abilities and wireless range. Due to the modular nature of the entire Cvolution system, It can easily be reconfigured and used as a backup focus handset or could be used as a 2nd camera focus handset on an Alexa plus show.
*Cvolution Advanced knob #1 has the new upgrade to use premarked focus rings (for lens mapping) and new backlit LED focus ring lighting as well as all the other Advanced Knob features.
*Cvolution Advanced knob #2 does not have the upgrade but does have all the other advanced features like adjustable knob drag, adjustable hard stops, ring illumination, etc. I use this one for the DP to pull iris from DIT cart and by the way, Cmotion handset knobs can be switched to work on either side so lefties can use it as well.
*One as new, unused Cvolution modular iris slider which can be used on either handset, usually on the main focus pulling handset.
*One as new, unused Cvolution Czoom module which can be used on either handset. Focus puller or DP can do zoom moves.
*New unused Cvolution Camin 3M MDR. This MDR is brand new, very small in size and weight which is great for Steadicam or 3 axis gimbals but has lots of features including the ability to use up to six motors total. Calibrate button now on the MDR as well as at the handset, many other features like Cinetape compatibility, etc.
*Three Arri CLM4 lens motors (one is as new/ unused. The other two are pristine) for Focus, Iris and Zoom. Strong and quiet. These are the latest motors from Arri and they are awesome. One of them also has the Jerry Hill style rosette adapter to use his PAM mount in addition to the regular sliding rod clamp assembly.
*Six handset batteries and a charger.
*Set of three pre marked focus rings (short, medium and long throw lenses).
*Two blank rings.
*Two iris slider marking strips.
*Handset neck strap with secure quick release assembly.
*Power cables for MDR including P Tap and Arri 2 pin lemo power.
*Run/stop cables for Arri, Panavision and Red.
*Three lemo connector motor cables to MDR.
*Three FISCHER connector motor cables to go directly to Alexa Plus or any Arri camera with motor ports.
*Soft case for everything.
More than $36,000 in gear. Most items are unused and everything else is in pristine condition.
Optional:
*Cmotion Cworld unit. Creates a wifi connection at camera and sends MDR and lens data to any wifi enabled device (phone, tablet, computer). Completely secure transmission with admin and guest access. Change settings, create/edit/load lenses into the Cvolution. Even create your own pre marked rings (creates the data to send to Cmotion and they will make the rings. Great if you own your own lenses). Shows Cinetape and lens data on screen. Focus puller can see cinetape readout and virtual lens barrel data on an iPhone or iPod attached to the handset. DP can see iris changes from an iPad, etc.
Cworld System comes with:
*Cworld unit (about the same small size as the 3M MDR) with Lens data license and cinetape data license.
*Cbus data/power cable from MDR to Cworld unit.
*Cinetape data/power cable (will power the cinetape from this same cable).
*Camera mounting bracket for Cworld.
*Universal mounting bracket for phone or iPod to handset.
*Cworld power/data cables for Arri Alexa (short and long).
I love my Cvolution systems and so do Focus Pullers and DPs. So much so that I got rid of my Prestons years ago. My Cmotion systems have proven themselves day in and day out on big feature and long form television. Some of the recent feature films I have used my Cmotion systems on are:"12 Years A Slave", "Lee Daniel's, The Butler", Spike Lee's "OldBoy", "This Is The End", "Endless Love", "Looper", and the soon to be released Will Smith film, "Focus". I have three systems now but I can't keep all of them. To see more details about all that the Cmotion Cvolution system can do, visit www.cmotion.eu or the U.S. Rep/Service division, Camadeus at www.camadeus.com
By the way, this one is available right now with no long wait time. Every bit of this gear was purchased direct from Cmotion through Camadeus here in the US. This system has so many features available I can't list them all here.
Buy the full two handset FIZ system without the Cworld kit for $28,000.
Add the complete Cworld kit with cables and brackets for $2000 more.
Will sell as a single handset FIZ system for $21,000 complete with Handset, advanced knob, zoom module, iris slider, Camin 3M MDR, three motors, cables, batteries, charger, brackets and soft case. A ready to use system that performs day in and day out.
Serious only please. I am not splitting up the package at this time other than the single handset system as stated above so please don't ask. Photos will be posted. Email only to:
graysonaustin@me.com
Thanks,
Grayson Grant Austin, SOC
*Two blank rings.
Optional:
Thanks,
