Tyson Birmann
- Feb 28, 2013
I'm hoping I can get some help understanding something I'm seeing in the footage.
In a RAW file, the RMD settings on affect the display of the image not the recorded image data.... Correct?
If I want to see the best representation of what is actually being recorded by the sensor and RAW file... I should look at REDLogFilm an "zero out" all other settings... RiFor now let's assume both of those ideas are true..
My question is regarding IRE. It would seem to me, overexposed = +100 IRE. Meaning, if I have NO detail because of clipping... That should read 100 IRE in REDLogFilm (or any gamma) assuming I haven't messed with the curve and all settings are neutral. As long as I am not changing the signal power input or output levels clipping should always show as 100 IRE, yes?
My problem is, I'm seeing my clipped portions of the image as flat lines that plataeu at around 60 IRE. How can the sensor lose detail at 60 IRE?
This makes me think that the R3D file isn't a true RAW file and that the RMD settings that were used in camera were actually changing the recorded data out of the sensor.
I guess the real question is: are there R3D settings (Look setting in camera) that superseed the RAW data? Are there settings that are actually changing the latitude, exposuere, etc... Of the recorded file?
