Cinegears wireless follow focus upgrade
James Kuo
REDuser Sponsor
Beijing China
The newest Cinegears Wireless follow focus Controller and Motor has 4 new response modes.
The users now have four different respond speeds to choose from.
The respond 1 mode has the fastest respond.
The respond 4 mode has the smoothest respond.
Switching between four respond modes can be easily achieved from the controller.
For Standard Controller,
Press O+REC+A at the same time will switch to response 1 mode
Press O+REC+B at the same time will switch to response 2 mode
Press O+REC+C at the same time will switch to response 3 mode
Press O+REC+D at the same time will switch to response 4 mode
For Mini Controller, press A+B to enter into function selection manu.
Press B to select Function 8.
Press REC to enter Function 8
Select one and then press REC will switch to response 1 mode
Select two and then press REC will switch to response 2 mode
Select three and then press REC will switch to response 3 mode
Select four and then press REC will switch to response 4 mode
The motor is also improved to reduce stepping from happening at low speed.
We also removed the function that speed nob can have direct control of the speed in real time.
This upgrade require both the motor and the controller.
And the upgrade can be achieved through RMA on Cinegears website
http://www.cinegears.com/rma/
For anyone that purchase the wireless follow focus:
within 3 months from receiving your units, this upgrade is free
within 6 months from receiving your units, this upgrade will cost $49
within 1 year from receiving your units, this upgrade will cost $79
We appreciate the support from this community.
This upgrade is not necessary be for everyone, the new features are for specific type of users.
Sincerely,
Please check this video for reference:
James
