tim ara
REDuser Sponsor
- Jun 28, 2013
- LOS ANGELES, CALIFORNIA - USA
- www.cinoflex.com
$5100
great alternative to preston or wcu FIZ
perfect condition!!!
Just serviced and checked by Panavision where it rented
Chrosziel MN-300KIT-Z-H overview
Wirelessly control your lens with precision using the Chrosziel MN-300 MagNum 3-Axis Wireless Lens Control System. This version of the kit comes with 3 Heden digital motors for interfacing with your lens of choice. Your motors connect to the included receiver and extension module using the included cabling. A battery, antennas, and straps for the hand unit are also included. The zoom rocker fixes to the rear of the hand unit enabling smooth and ergonomic control of the zoom axis. For transport and storage, the kit fits nicely into the included hard case. See below for more information on the individual items in this kit.
MagNum 200 2-Channel Wireless Lens Control Hand Unit
Chrosziel's MagNum 200 2-Channel Hand Unit for the MagNum wireless lens control system can remotely control focus and iris. Focus is controlled with a fluid-dampened hand wheel. Hard stops can be set along the focus rotation for focus marks. Iris is controlled with a linear slider on an aluminum scale. Compact in size, the transmitter has a rounded handle with a finger grip on the rear so you can hold it securely while operating. The transmitter houses an internal 2.4 GHz antenna and a BNC spigot that will accept an external 434 MHz antenna. To avoid issues with radio interference, there is an integrated spectrum analyzer that can determine the best frequency for transmission. Menu navigation is done by way of an easy-to-read OLED display and membrane directional keys. Included with this transmitter is a BNC antenna for 430 MHz operation, and a hand strap.
MagNum 200 2-Channel Wireless Lens Control Receiver
With dual outputs, the Chrozsiel MagNum 200 Dual-Channel Wireless Lens Control Receiver can drive up to two motors that connect via 7-pin LEMO. The receiver is capable of calibrating motors to the lens without the aid of the transmitter. When connected to a camera via the serial output, start/stop can be remotely controlled from the transmitter. The MagNum 200 system can operate on 2.4GHz and 430MHz frequencies for ensuring the greatest possible working distance and reliability. The 2.4GHz antenna is built-in and a BNC 430MHz antenna is included. The the receiver can be used in a wired/studio configuration drive motors with input from ENG demand controls. Using an Aladin extension modules, which are mountable to the receiver body, the MagNum system can control up to four motors in total.
MagNum Extension Module
Attaching the Chrosziel MagNum Extension Module to the MagNum 200 Receiver expands the MagNum system to be a fully functional 3-axis lens control solution for focus iris and zoom. The Extension Module has a 7-pin LEMO connection for a digital motor and a 12-pin Hirose connection for connection to ENG cameras for iris control and VTR/talkback control.
Zoom Rocker for MagNum MN-200/150
The Zoom Rocker from Chrosziel is designed for use with the MagNum MN-150T Extendable Transmitter or the MN-200T Extendable Transmitter with antenna. It includes a personal code to activate the zoom software module.
Compatibility
MagNum MN-150T Extendable Transmitter (2016 or later models)
MagNum MN-200T Extendable Transmitter with antenna (2016 or later models)
Compatibility
