CHEAPEST EPIC RENTAL IN LA, $295. DP deals as well, Zeiss CP2 kit, RED Clutch Rig, +
James_Mills
RED Epic DRAGON, DSLR, and production equipment rental; director / DP for hire (see http://millsmovies.com for reference work).
295 dollars a day gets you the entire Zeiss CP2 lens kit. Varied rates available for extended shoots.
445 dollars a day gets you the standard DRAGON Brain, side SSD, and PL Mount or Canon TI Mount. Varied rates available for extended shoots.
595 dollars a day gets you everything listed below under the RED Equipment section. Varied rates available for extended shoots.
795 dollars a day gets you ANYTHING listed under my RED and CAMERA / LENS equipment list as well as myself on set to DP, operate, or oversee / assist with anything. Varied rates available for extended shoots.
1,045 dollars a day gets you ANYTHING listed under my RED and CAMERA / LENS equipment list AS WELL AS THE ENTIRE CP2 LENS KIT and myself on set to DP, operate, or oversee / assist with anything. Varied rates available for extended shoots.
RED EQUIPMENT:
RED EPIC DRAGON MX
RED "Clutch" Shoulder Rig
Rear SSD and PL mount + Canon TI Mount
RED 5" Touch LCD Monitor
RED Grid 5"Monitor Viewfinder
One 256 GB RED SSD Card and Two 128 GB RED SSD Cards
One REDMAG Station (1.8")
Tilta AB Mount
Two 95wh GMP batteries, one 165wh GMP battery
Two GMP chargers
DSMC Side handle
Two Redvolt batteries
One Redvolt charger
Arri MMB-2 w/ side flags and eyebrow, step down ring kit
Laparte Shoulder Mount and rig and swing away Matte Box (designed to fit Scarlet)
I-Focus Follow Focus with whip (designed to fit Scarlet)
Two Noga Cinearms
EI7063AA Fluid Head and sticks
Pelican 1510 Carrying Case and UTA Shoulder Rig Bag
ZEISS COMPACT PRIME 2 SUPER SPEED KIT (CP2 SUPER SPEEDS)
21 mm prime, t 2.9 aperture
35 mm prime, t 1.5 aperture
50 mm prime, t 1.5 aperture
85 mm prime, t 1.5 aperture
OTHER CAMERA AND LENS EQUIPMENT:
Canon 5D MK II camera (with five batteries, four chargers)
Panasonic GH2 camera
Panasonic LA7200 Anamorphic Adapter (with complete step up ring and diopter kit)
11-16mm, f2.8 Tokina lens
24-70mm, f2.8 L series Canon lens
70-200mm, f2.8 L series IS II Canon lens
50mm, f1.4 Canon prime lens
100mm, Macro f2.8 Canon prime lens
Sankor 16C Anamorphic lens
OTHER GOODIES:
Steadicam - Glidecam X - 10 with 4000 HD sled. DP4 monitor included.
Kessler 8-14foot Crane
Dana Dolly with c-stands, poles, middle extension base
Rhino Pro 4ft Slider with suctions and pully
Flolight 3 point Kino Kit
Red Rock shoulder rig and follow focus
Jag 35 Straight Rig
Marshall 7" monitor
Manhattan 7" monitor
GoPro Hero 2 with moto-mounts, surf mounts, and head straps
H4n ZOOM audio mixer / recorder
Sennheiser G3 Lavalier microphone
RODE VideoMic PRO
8 foot slider with fluid head
Kinova tabletop dolly with fluid head
6 foot dolly track
Rycote Invision Stabilizer
600 watt spotlight
Two portable 160 LED lights
Double hot shoe converter for one man crew
15" MacBook Retina Pro with 16GB ram for fast data wrangling and DIT work
Multiple SD and Compact Flash cards
VeriZoom Fluid-head Tripod
Perfect 3.0x Viewfinder
Addition Run'n'gun rig
For reference, here is my reel: https://vimeo.com/86299615
And other work at my website: http://millsmovies.com
Contact me via email at jamesATmillsmovies.com or call me at 562-413-9492
Chill
Chill
Yes James, you have every right to rent your gear on whatever basis makes sense to you. Free country and all that.
Justin also has the right to be upset that your choices are driving down the market and thereby making it more difficult for others to pay their bills. Keep in mind that even if you only rent out your kit a couple days a month, every producer in town uses your rates to bargain the rest of us lower.
If you don't like the blowback I suggest you market your services elsewhere. BTW, are you a RedUser sponsor? Using this resource to buy and sell things the way one might use a classified ad is kosher, using it as a free advertising platform for an ongoing business is something else. I appreciate the fact that you have spread out your posts over time, and on several occasions had "news" about your rental kit to report. I am by no means accusing you of rampant abuse. What I am saying, is that if you decide to use RedUser for your commercial purposes you might just have to accept some criticism as part of the territory.
Cheers - #19
Cheers - #19
I wasn't aware that there were guidelines to posting in this section. Are we not allowed to update our posts? Are bumps not allowed? I'm perfectly fine with them deleting this thread anyways; as I said, it's not as if I'm getting rentals and if people like Justin are going to call me a "loser" (even if he did edit his post after) in the process then I'll just move on. You stated he's allowed to criticize, but I don't find that to be criticism, let alone constructive criticism.
As it stands this thread is simply more embarrassing than anything. Mods, can we either delete this discussion due to its irrelevance to the thread or simply delete the thread entirely? I decided to rent my gear out so that I can make an extra buck on my days off while also trading favors and networking, but neither has happened frequent enough to stand for the slandering of my name.
The only guidelines for posting in this section is that you have to be renting out a RED camera kit of some kind. Other than that, it doesn't matter who you are or how you go about your business. Justin is entitled to his opinion, but he's out of line by crashing into your thread. It's a free market and you can rent your gear for $5/day if you choose. This is a cyclical discussion that never seems to go away. Blair points out that your rates, whether your gear is being rented or not, are factored along with everyone else's and used to direct the market. People see someone advertising a low rate and they use it to try and strike a bargain with their preferred rental provider.
Your rates are cheap, but hardly the lowest I've seen.
Agreed, there are some people renting out Scarlet packages for $100 a day here in NYC. So yeah......
I apologize for the original post. I speak my mind a bit to freely sometimes (after a few beers) and I apologize. I can't say it better then the other guys. It's the Walmart way. I wish you the best and hope you shoot often with your gear and don't get bogged down with renting your gear. Enjoy your camera and be careful when renting it out. You might get $600, but all it takes is one dumb ass to put you out of business for months on an insurance claim.. Sorry to derail your thread.
-- Justin
