Rainer Fritz
- Apr 5, 2007
- Age
- 48
- Vienna
- www.aacamera.org
So it seems it is the red SATA cable coming from the camera inside to the CF module, and there specialy the SATA connector. The cable is too inflexible, the connector not tight and turning the connector that a not proper connection is the result.
There should be a possibility to tighten the cable on the cf module.... it is boring and dangerous that after some days specialy when its cold and the cable more inflexible to put the cf module out and try to fix this problem...
CF cards then dont mount or sometimes mount and then not....
Data integrity is ok so far it looks like....
best,
rainer
best,
rainer
