- Banned
- #1
Erica Duffy
Banned
This lens has been lightly used but excellently maintained. Any signs of cosmetic wear and truly difficult to find. The glass is flawless, the lens is practically new. The Canon CN-E 30-300mm T2.95-3.7 L S EF Mount Cinema Zoom Lens features advanced optical technology designed by Canon, the lens is suitable for any capturing any size HD image up to and including 4K resolution. With a focal length range of 30-300mm, the 10x cinema zoom lens is designed to cover the longer end of the focal lengths typically required by cinematic productions, and its maximum telephoto length of 300mm puts it among the best in its class. Maximum aperture is a relatively fast T2.95 throughout much of its range, and the 11-blade iris enables a smooth bokeh for out-of-focus areas of the frame.The lens was designed with working professionals in mind, with easy-to-read focus, zoom, and iris markings engraved into angled surfaces on both sides of the lens, so you can read the setting from either side of a camera – or from behind it. Depending on the production's needs, focus markings can be switched from standard to metric. The lens facilitates manual operation that's subtle, smooth, precise, and repeatable. Control rings are designed to provide and maintain the proper amount of resistance so you can operate with a consistent torque. The focus rotation angle is about 300°; for zoom, it's approximately 160°.
We are also selling a set of 6 Canon CN-E prime lenses and a Canon CN-E 15.5-47mm lens, message for details!
Don't miss out on this incredible deal!
