Camera Looked best at Default Settings.
Matt Bai
Going back and looking at Epic-W footage shot before all the black shades and noticing it looks the best. Any way to get the default from factory setting back on sensor?
It should be saved as a default called "factory" under your black shade presets. Note that when you're doing a black shade, it's important to let the camera get up to operating temp (whatever you have your fan settings set at - best to leave on adaptive) before doing a black shade. That's probably why the footage doesn't look as good. Need to let the cam get up to temp. Also, best to do an auto calibration - takes about 45 minutes or so, but it's well worth it.
If you doing the auto i sugguest you put in the dc adapter or use a larger battery. I did one on a the red brick and it was not battery left after the autoshade was done.
