Camera doesnt remember project settings
Sean Porter
www.seanporterdp.com
I don't recall this happening pre-build 21, but my camera no longer remembers project settings after a power cycle. This means every single time I change the battery I have to re-set the frame size, iso, audio rec settings, frame rate, etc. I know I could save a preset, but even that is too much to do every time the camera gets turned off!
Is there something I'm missing or a setting that is currently set to restore factory defaults after every power cycle?
Thank you much in advance!
Sean
No the camera should remember settings and time - there must be a faulty memory backup battery/capacitor circuit - since there is no battery compartment, that must be a back to RED or other authorised repair centre repair.
