Peter Cote
Hey all I'm doing a shoot on Phantom Miro in France. It's more like a studio shoot so everything will be run off of wall power but all the gear I'm using is from the U.S. The whole foreign voltage adapter vs voltage converter thing kind of scares me as I have fried some electronics before while traveling abroad. The thing I'm most worried about is frying the AC power supply for the Phantom Miro. Any advice or guidance would be helpful.
I've also heard that foreign adapters aren't always supposed to be used for a long time or they could still fry even when used with the correct settings. Below is everything I need to power with two adapter/converters that are rated up to 1600 watts. Let me know if you think it would be an issue powering all this stuff for about 4-5 hours.
Phantom Miro
TVLogic VFM-058w monitor
MacBook Pro
3x LED Panel (each pulls about 70 watts)
Phantom Miro
MacBook Pro
