- Banned
- #21
Robert Ruffo New
Banned
Horrible CRI, horribel skin rendering. Crap.
I experimented with a 100watt LED (I just bought the LED and power supply like this http://www.ebay.com/itm/100W-Cold-W...704?pt=LH_DefaultDomain_0&hash=item35cdafbb40) that I put in a mole richardson baby housing. It wasn't green just a little on the blue side, I rather liked it. Very crisp "winter light" looking. I wouldn't automatically fear green. the nice thing about LEDS is you just put a piece of 1/8 minus or whatever on the lens, and it lasts forever. I have been meaning to buy a couple of those chinese led fresnels for a while now. I may get around to it soon.
Nick
no you can't, because it si a green spike, not a shift toward green - not the same. CRI will still be utter crap
FWIW, I couldn't help myself and ordered a unit to test. To be specific and clear, I ordered the 150w unit from Came listed in the link at the start of this thread. I'll report back on my impressions when I get it. Wish me luck.hmy:
I'd be interested to read your thoughts Terry - I'm having mixed results with the 'cheap' (or 'budget' depending on your perspective) LEDs - but not come accross these Came ones
It is due to arrive today. I probably won't get to test it much until later in there week but I'll try to give some impressions as soon as I can.
Sorry guys. Delivery got delayed and it is now due today some time. I have to be out of town until Friday so it looks like the weekend before I can test it.
So, I finally had some time to spend with this light. The results were kind of surprising so I don't know whether to be delighted, surprised or confused. LOL This was not scientifically rigorous so take it all as loose and observational but it was revealing at a least to me.
To start with the basics, the build is pretty solid - not bullet proof but better than I might expect from your basic, inexpensive Chinese product. No loose screws, no misfitted parts, etc. The connectors were solid which I am really happy about as I have had trouble with this on other Chinese fixtures. I think they may be learning something from previous failures and, overall, I think the light will last fairly well. It was bigger and heavier than I expected but that was because I was expecting something about the size of my Coollights CDM150 Fresnel. Turns out this one is bigger and beefier.
The barn doors are sort of permanently affixed - well, get out a screwdriver and you can remove them - but I don't see much of reason to take them off, anyway.
FWIW, it comes with two plastic "lenses" for color temp changes - amusingly, both the amber and the clear lenses are marked "3200K." LOL I tested it with the clear/frosted lens and then realized that you probably don't need either cover if you plan to WB to daylight. Might even gain you a few FC. I usually don't shoot tungsten so I haven't yet fooled with that.
There is an internal fan which is actually very quiet but, if noise is an issue, there is a switch on the back to turn it off completely.
The focus knob is pretty smooth. I didn't measure but at full spot is it pretty much a narrow spot. At wide open, it still isn't really a flood but I think you could light a two shot MCU without a problem.
Brightness - Actually, seems pretty good on that score. I am sure it is nothing near the 1500w equivalent they suggest - at least by the name on the fixture. I am thinking it may be fairly compared to a 650 or maybe a bit more. I'll have to do further testing to get a handle on that.
It is fully dimmable but it doesn't seem like the range from full to low is that huge. It is very handy though to be able to easily dial down a couple stops and there didn't seem to be any color shift at all. Again, I didn't measure carefully but from a purely visual standpoint, it seems good.
The big issue is, perhaps obviously, whether the color balance is usable. My first impression on firing it up was that it did, indeed, seem to be a good solid "white" beam; no noticeable green at all. But, of course, eyes can be deceiving so I took it a bit further. This is where the results were surprising so I am glad to hear of any suggestions as to how I can reasonably test it further, or evaluate it differently.
To test the color, I first put a white card into full sun (actually, I didn't have a proper white/grey card available so I had to use a piece of bright white printer paper). Then, I shot a few seconds with my fully warmed up Scarlet set to 5600K. Then, I did an auto WB in the camera a shot a few more seconds. The theory here was just to get a proper baseline with my camera and the piece of white paper. Next, I moved over to the other side of the room - very little sun through the windows and no artificial light except for the Fresnel. Again, shot straight 5600K, tint at 0, then did an auto WB. BTW -since I realized I was working with some daylight "spill" from the windows, I then performed this same test in a dark closet - no daylight, no other artificial light. FWIW, the results weren't much different on these last two.
After shooting the test footage I took it into RCX. So, when I did an auto WB on the paper in full sunlight, I got a color temp around 5500K with a tint value of around +2.5. The scopes in RCX were, obviously, pretty even and the white was pretty neutral. When I looked at the footage lit by just the fresnel, it again looked pretty neutral with the auto WB (in camera) footage having readings of around 5300K and a tint value around +11.5. BTW - predictably (I think?), whether I did auto WB in camera or re-set and did it with the eyedropper in RCX, the results pretty much matched.
So - what did I see? I really did expect to see something of a green spike or tint but where was it? There was no spiked green bar in the histogram and the waveforms were pretty much at equal levels or R, G and B, and pretty flat as well. While the tint number 0f 11+ seems like a pretty high number, futzing with it a tiny bit between 0 and 15 didn't yield any super-dramatic shifts in color either. And, at +11.5, the tint was actually shifted in the direction TOWARD green. Isn't that the opposite of what I would expect if there was a "green spike?"
So - any thoughts? I clearly should test with skin tones but, like I said, should I be impressed? Confused? Skeptical? :huh: At this point, I am kind of optimistic.
Good input, Matt. I would have thought that any spikes like this would somehow reveal themselves on a histogram or videoscope. No?
