Buying Walkie Talkie set; help?
Justin Anderson
I'm looking to buy a set of walkie talkies w/ headsets for an upcoming film I'm producing.
I want to be able to use these on my next films too, so I'm looking for something good.
-What features should I be looking for?
-Any brands I can trust?
-Should I buy used?
http://tinyurl.com/9fjn4q
^^^I found this. Thoughts?
thanks,
-Justin
The set you found is a marine radio. You probably need UHF, not VHF. You may also like to check the power output. Better hand held units have switchable 1W/5W, which you may need for longer distances. Most major brands are OK. You may like a solid, metal-cased model. I use a pair of marine (because I mostly operate in the ocean) submersible Uniden MHS450 and I like them very much. Very clear and reliable reception. They have equivalent UHF terrestial units.
In the USA, walkie talkies that will transmit to a distance of 5m or more need an FCC license, and they apparently do levy fines occasionally. Either take your chances, get the license or buy a less powerful walkie talkie.
http://en.wikipedia.org/wiki/Walkie-talkie
Apparently its the ones in the 900mhz and 49mhz ranges that don't require a license.
Uniden have good reputation in wireless stuff
Uniden.
So I've got uniden, motorola, kenwood, icom. Which one should I go with?
-I'm looking to buy a set of 5-7
-I need in-ear headsets for all of them
I don't know enough about walkies to know which features should be important to me. Anyone have anymore advice?
thank you,
-J
Hi Justin. I have a set of Motorolas that I bought new from an on-line dealer. Google and a lot come up. I think I paid about 2k for a set of 6 of them. The important thing for me and you may want to consider ...before buying, I called an LA rental shop and they faxed me the frequencies and PL codes that they use. I then had the dealer program my radios to match with those from the rental company and now when I want to add radios for larger shoots, I just rent some more and the Freqs etc. match. very handy.
Larry
Larry
Hey, thanks!
What's the functional difference going to be between buying VHF or UHF?
