BUILDING A BEAST HACKINTOSH, NEED HELP
I'd Personally opt for a 6core minimum such as the 3930k, which offers up to 64gb of ram limitation versus 32gb on the 4770k. Since the 4770k are the latest haswell chips, performance might be close. I'm sure you'll overclock the cpu anyways, but the 6core option will give you more headroom with 50% more cores.
There isn't support yet for TB on the hackintosh side. Asus is releasing a TB2 board, as well as Gigabyte will soon release their TB boards. So I'd wait if you really need TB on the Z87 platform. The 4770k is still going to be quite a bit slower in overall rendering times vs the 3930k, the only main advantage is lower power consumption and slightly better gaming performance that uses only 1 or 2 cores.
There isn't official support in OS X for Haswell yet... or at least nothing has been released other than betas and hacks. You'd have to run a beta of 10.8.5, 10.9.0, or a hacked 10.8.4 kernel, so you're bound to have issues until an official release that supports Haswell.
The Titan will be crippled a little until 10.9.0... although there may be better support in 10.8.5. Until then, no OpenCL and Premiere CC and RecCine-X Pro 18 Alpha won't run.
If you're only running OS X, there's no reason to get the i version of the PSU. The software that comes with it won't run in OS X. If you're going to run Windows also then it's fine, otherwise you might be able to save a little money. I an an AX1200 non-i myself.
The audio chipset on the motherboard you picked is not yet supported in OS X and I don't think there's 3rd party drivers from the Hackintosh community to get it working. Same with a lot of Z87 motherboards, so it's something you want to look at along with the other chipsets on the motherboard.
Asus just announced that new Z87 motherboard with Thunderbolt 2. Should be out in the next couple months. The motherboard you listed is Thunderbolt 1. Keep in mind that Thunderbolt is not hot-pluggable on a Hackintosh. I found it rather unusable because of that personally, so I switched to the Maximus V Extreme. That's a Z77 board, but they have a Z87 version in the Maximus VI Extreme. It gives you more x16 slots, more lanes, and has a Thunderbolt header (the port/board for it isn't available yet though). No one knows if that's Thunderbolt 1 or 2 on that header.
Thanks Mike, Premier wont run with a Titan right now?
No. It seems to me that Premiere CC requires OpenCL to be working if using a card that should have OpenCL support. The problem is that the current drivers built into OS X 10.8.4 and earlier don't support OpenCL on the Titan. Nvidia's web driver also doesn't get OpenCL working. So Premiere CC will not run, but Premiere CS6 will. That's an odd one, but it's because Adobe didn't have OpenCL support in CS6. Same goes for RedCine-X 18 alpha. It won't run, but v17 will.
That said, I got hold of the drivers from OS X 10.9 Developer Preview 5 and installed them in 10.8.4. That made Premiere CC and RCXP 18 alpha run, but I must have missed a driver or there's some other under-the-hood change that I'm missing because it did break OpenGL, so I reverted back. I'm okay running RCXP 17 and CS6 for now. OS X 10.8.5 may get released tomorrow, and it's possible that will add OpenCL support for the Titan so we'll see. At worst, 10.9.0 is only a couple months away.
