Philip Lima
Our scarlet will not boot up with certain V-mount batteries. The red light on the side of the camera is illuminated, then when I push it to power on, it goes off and the fan kicks on for a few seconds. Then, about 5-8 seconds later the fan turns off and the red light illuminates again. If I switch batteries or plug it into AC, it boots up no problem and shows the camera was not shutdown properly warning box. The primary battery I'm having this issue with is the ikan IB-TR190S http://www.bhphotovideo.com/c/product/903307-REG/ikan_IB_TR190S_Professional_Battery_with.html but I've also had the issue with some of our IDX batteries as well.
Since we also have an Epic M with the same exact V-Mount battery setup, I've swapped that and the issue persists only with the scarlet. Our Epic boots just fine with the same ikan batteries every time. I've also swapped every RED component between them to try and get the Epic not to boot (side handle, touch screen, PL mount, EF mount ect...) and no matter what I remove from the scarlet, it won't boot and the epic boots with everything no problems.
RED bricks and AC power work just fine on both cameras, so it's just something with these ikan and IDX batteries and the scarlet itself. Does anyone have any similar experience that might shine some light on the problem? Since it really isn't broken (still works fine with RED batteries), I don't really want to send it back to have RED check it out.
