Sean Sweeney
- Jun 1, 2008
Hi folks,
Strange problem cropping up. Back in 2008 there was an issue where sometimes a dynecke would cause the red to not boot properly - the rear LCD would blink on and off at 2 second intervals (approx). Removing the timecode cable solved the problem
Cut to 2011, with Build 30.7.0 on our MX - and the same problem just showed up. Once again unplugging and replugging the timecode cable seemed to be the only way to get it to boot. Swapping power cables, batteries, and unplugging monitoring cables didn't seem to affect it.
Anyone else have this on their build? The only results on the forum seem to be from 2008/2009, when this issue was more prominent.
Thanks in advance.
Thanks in advance.
