Blackmagic Design HDMI to SDI converter not passing signal from Scarlet?
Jeremy Hildebrant
Wondering if anybody could help me with this.... I have a hdmi Marshall monitor with loop thru and a Flanders SDI monitor. I want to come out of the Scarlet HDMI into the Marshall and then back out while using BMD's mini HDMI to SDI converter to convert the signal for the Flanders monitor..... but it doesn't work, the Flanders just says no signal. This also doesn't work if I bypass the Marshall altogether and go HDMI out of the Scarlet into the BMD converter and then SDI to the Flanders. Still no signal.
Works fine when going straight Scarlet SDI out to the Flanders, but I'd like to have the Marshall in the mix too. (the Marshall also works fine hdmi from Scarlet) So I am not sure if it is the converter is killing the signal or if the Flanders is not reading it...? (the converter does work when sending the signal from a 5DmkII to the Flanders though).
Any thoughts, am I missing something? Thanks!!
