Better or Worse than Super35 Sensor?
McKay Olson
Active member
Since the 4K will be cropped, does that make the sensor to the Scarlet larger or smaller? Thank you!
4K is more or less Super-35, slightly smaller but hardly worth worrying about.
Various widths:
36mm = FF35 / Canon 5D sensor
30mm = entire M-X sensor
27.65mm = 5.1K area of M-X sensor (Epic 5K mode)
24.4mm = 4.5K area of M-X sensor
24mm = Super-35 film
22.3mm = Canon 7D sensor (APS-C)
22.12mm = 4K area of M-X sensor
16.59mm = 3K area of M-X sensor
11.06mm = 2K area of M-X sensor
Thanks David! I was looking for the 4.5k dimensions myself.
G'day David,
WOW! So the working area of the MX Sensor at 4k is only 22.12mm , much closer to Academy standard than S35 !!!
What exactly does this mean if your using Aspherical Cine primes? Say an Arri ultra prime 10mm with a Angle Of View
0f 110 degrees?? how will this translate with the sensor area being covered??
