Robert Hofmeyr
Hi Rob, I think you are right that I maybe dont need the rails. I'm sure I could put something on the RRS Kennan Ward bar. So just so I understand. The bolt that is what the follow focus cogwheel will sit on. But what is the bent rail for?
I talked to Tom and he recommended the RTMotion instead. If you get the full setup its 2-3x more expensive than Redrock of course. I will need to redup on the latitude. Would you use these for the same purpose or what would you use them for?
I will be sure to put up some of the puffins when I finished editing the. I got one that is taking of with the mouth full with fish!
Cheers
/Andreas
Hi Andreas,
The bent bit is just a bracket to attach the short rod to your bar. Not sure if it will be the right length, so you may need to have something made up.
The nice thing about the RTmotion system is you can just buy a latitude and a thumbwheel or smart knob initially (these will allow you to start/stop and pull focus via internal motors of your lens) and see if they suffice, then upgrade with controller, motors etc. later.
Rob
