BETA RELEASE: REDCINE-X and REDline (Build 356)
Status
Not open for further replies.
Brent Carter
REDUSER.NET
Irvine CA
Posted on RED.com: https://www.red.com/support/5/release_history
* REDCINE-X and REDline for OSX - Beta Build 356:
* REDCINE-X and REDline for Windows - Beta Build 356
Changes since last alpha release (Build 351):
* REDGamma2 and REDColor2 added to REDline help.
* Fixed crashes when loading certain RMD files.
* Fixed bug where 3d clip exports weren’t respecting in and out points.
* Fixed REDline bug where —useRSX 2 would use in and out points from the RMD file.
* Fixed ReelID and AltReelID output from REDline.
* The mouse wheel will no longer scroll drop downs.
* Improved error messages for the “move to trash” operation.
* Fixed crashes when loading project files or R3D’s from the Finder on Mac.
* Fixed bugs with multiple “Save As” dialogs appearing when the Export button is pressed multiple times.
* Fixed coloring issue with drop downs in the Export Settings dialog.
* 64-bit REDline is now functional.
* Rubber-band selection in the browser will now scroll the view if necessary.
* Improved thumbnails seen when dragging clips in the bin and browser.
* Fixed the “too many open files” bug in the bin and browser for 64-bit Mac builds.
* Fixed bug where the Shift-Z shortcut was not working.
* Added REDCODE and “Record framerate” metadata fields.
* Fixed hit region of buttons on Mac.
* Framing performance improvements
* Fix for Avid 16 char edl’s not relinking correctly.
* Fix for off by one FCP XML import.
* Better slug handling for FCP XML import/export.
* Better clip handle support for export FCP XML’s.
* Handle FCP XML transition items, so no frame dropping occurs on import.
* Properly quote paths in REDLine batch scripts.
* Video window zoom improvements.
* Fixed backwards copy during Top Bottom 3d exports.
* Always use filename of left clip for 3d exports.
* Added Growl Batch Finished notification.
* Export handle size increased to 100.
* Can now refresh currently selected look and framing presets.
* Fixed 3d offset behavior.
* Fixed timeline clip split bug, where a duplicate frame was introduced.
Please see release notes and/or readme files for further details.
ALWAYS READ ALL INSTRUCTIONS CONTAINED IN THE DOWNLOADED INSTALLATION FILES BEFORE PROCEEDING.
WARNING: AS THESE ARE BETA BUILDS, THEY ARE RECOMMENDED FOR PREVIEW AND TESTING PURPOSES ONLY. THEY ARE NOT RECOMMENDED FOR USE ON COMMERCIAL PRODUCTIONS.
Post here for community support. Contact tech support at https://www.red.com/contact_us/new for direct support from RED.
Thanks, BC
Status
