[FS: GEAR] Bebob Engineering ML-120 Hot Swap Adapter for Red One Camera
Atlanta, GA
I have used Bebob Hot Swap Adapter for the Red One.
(Bebob Engineering ML-120 Hot Swap Adapter for Red One Camera) - Product Identity on B&H Photo
Selling at 400 USD. Last checked on 04/23/17 to see that item was working properly.
Will also throw in some brackets as extra. 19mm mounting system
Hello Myoung,
I may be interested in your unit.
I had a used Bebob Rogue that worked very but stopped working.
I bought a new Bebob Rogue but my Red One won't read the battery info.
My evf also shuts off momentarily when hot swapping.
When you tested your unit, did you notice either of these phenomena occurring.
Could you tell me if you have a version # next to your serial number and what it is?
Thank you
Brian
Hi Brian,
Apologies for the late response. Unfortunately I don't have an EVF or Red batteries in my set up, so I wouldn't be able comment on the issues you have experienced. I've been using gold mount batteries with an adapter plate.
The version my unit is showing is V1.3.
Hope this helps.
Myoung
