So I finally got a light meter and...I can't figure it out.
I'd learned to use an incident meter to expose for skin tones (which are apparently around 18% gray for caucasians)...and that's worked okay for me. This is my first "dualmeter," though and my readings are confusing.
When I use incident mode it tells me to expose about a stop brighter versus the reading I get on my skin when using the spot meter (metering the same part and using the hemisphere in the correct direction, facing the light). I repeatedly get this result, and the spot meter seems to offer the better reading (a stop under the incident meter).
Is this because my meter is mis-calibrated? I have relatively pale skin but not like unusually pale. I don't have an 18% gray card, but I'll buy one because I assume everyone will just tell me to.
Edit: And is it normal that I have to push kind of hard to turn the wheel from incident to spot? It's a sekonic.
