[FS: GEAR] B4B V-Mount Battery Set. $1,500
Asher Vast
I am selling my set of B4B Vmount batteries. I bought them all new directly from B4B about 2 years ago. There are no problems with any of them. They all maintain a full charge and last the expected amount of time. There's enough batteries here to shoot all day on any production camera without needing to recharge.
If I had to guess, I would say each of these batteries has been used between 20-30 times over the period of 2 years. This is nowhere near the expected 1000+ cycles each battery is capable of handling.
I paid $2,450 for this set new. Asking $1,500. I will only sell as a set.
150WH Vmount Battery (Paid $375)
230WH Vmount Battery (Paid $475)
A P-Tap power output port is available on the side for devices operating at 14.8V nominal voltage. It will provide up to 5A of power and are electronically and independently protected against shorts and overload so not to compromise the battery's main supply. A 4 segment LED gauge on the side confirms remaining capacity at the press of a push button next to it. There's no memory effect and the battery can be charged at any time. You can use any B4B charger designed for V-Mount Li-Ion batteries, such as the SM-C2 2 channel simultaneous charger. Or our TC-1 universal travel charger through the specialized side polarized DC connecter. As well as Sony or IDX V-Mount chargers
This model has some IATA restrictions and can be transported two per passenger in hand luggage, or in checked-in luggage if installed in your equipment. Always check latest regulations and with your Airline before travel if unsure of current restrictions.
Voltage : 14.4 V
Full voltage : 16.8+/-0.1 V
Cutoff voltage : 11 V
Mount type : V-Mount (Sony - IDX Style Mount)
