AUDIO OUT OF SYNC ON SCARLET
Christiania, Denmark
Hi i just got home from 2 days of recording,
after i uploaded the material to my mac i noticed my scratch audio from the scarlet is slightly out of sync
i recorded in 25fps, timebase at 25. i have the røde Ngt 2 attach to wooden camera A-Box
i can´t figure out what causing this?
I had a similar problem on my last shoot
some files out of sync and some fine
are you also running 3.2.8? curious if its the beta firmware issue
also, did you shoot any slow mo footage that day, then back to normal speed?
curious if there is a fault in 3.2.8 or earlier, that when switching back to 25fps from 48fps, the audio gets mixed up and stays in 48fps out of sync
yes I'm running 3.2.8 No i did not shoot any slow mo only 25fps. maybe it´s the firmware
Thanks for the reply
I had random amounts of sync problems in 3.2.8 as well as occasional echo/garbled audio on some clips that I had to ADR.
But has anyone noticed minor sync issues in 3.0.7 and earlier? It seems consistent and therefore easy to fix in post, but kind of a drag when delivering raw footage to a client...
