Audio on Raptor
Mike Seehagel
Vancouver, BC
mikeseehagel.com
Hi, bit of an odd question perhaps. When you guys plug a 5-pin lemo into your audio port, does the little LED beside the port light up?
I've been trying the 5-pin to 3.5mm cable and can't seem to get audio running into the camera. I have it set to external/ch3+4, mic input, etc and still no luck. Just curious if that light should be on, if it's perhaps an issue with the cable or maybe the port itself. The mic works on other cameras so that shouldn't be the issue, and I haven't had a chance to test with an XLR mic yet. Curious your thoughts!
Hi Mike, this LED should only light up blue when you enable phantom power for at least one of the mics. Switch Ch 3 or 4 from "Mic" to "+48V" and it should light up.
Ah interesting that seems to work! Also it must have been my cable or something, because when going XLR into the camera with the RED adapter everything works fine. Thanks!
