Brian Shephard
It comes with a bolt-on rod that works with any 1/4-20 hole (there's some on the top of the Epic).
Perfect. Thanks!
I tried these same cables at the office with a Sound Devices 442 and also with a Lectrosonics lavalier plugged directly into the Hosa adapter. I was able to get a decent signal, but experienced really loud handling noise if i even touched the Hosa adapter cable. It seemed like it would be unusable audio due to the possibility of that handling noise anytime the cable shakes just a little.
Has anyone had similar experience? It was only a $10 adapter, I thought maybe it didn't have proper sheilding.
Also, could not get a good headphone level - seemed very weak. In the quiet office, the headphone level was just loud enough for me to hear the sound, but not really strong enough to monitor or mix.
Did you go into the menus to raise the headphone output? Have not had any headphone problems.
I have been through all the menus, but can't find anything for the headphone output.
Can you tell me where in the menu system it is?
On the current release code, nothing that specifically says HEADPHONE, but go to SETTINGS / AUDIO _ VIDEO / AUDIO OUT
Move all those sliders to -9dB ( - 1dB is also fine ) and you should hear audio now...
Thanks Chris. You are still providing your own phantom power though right?
I'm trying the Hosa cable, both from a Sound Devices mix pre, and a Rode battery powered mic. Both no good. Any hints?
Does anybody know if there are any Epic-mountable phantom power devices?
I have used the Denecke phantom-powered box, and it works great. It's fairly old (I think at least 10-12 years), but just about all of Denecke's products are first-class.
