Astro HD MONITOR DM-3000 -Works great. Built like tank!
Ken Saltzman
Astro Design DM-3000 HD LCD Monitor.
It is used but in perfect working condition. Guaranteed Non-DOA. - $295
It is one of the toughest monitors out there. Built like a tank.
Power cable included with D-tap connector at other end.
The DM-3000 is a compact, lightweight and portable 6-inch HD monitor, which is used for camera and VTR check in remote broadcasting and at location sites as well as studios. It can be used with a camera battery, thus images can be checked wherever you go. A wide range of functions including brightness adjustment, contract adjustment chroma-level adjustment, and center marker display, screen frame display are provided. For input signals, SDI signals are used as standard, which is practiced first in the industry, supporting 17 HDTV formats. By exchanging the module at the input part, analog signals can easily be supported.
Features
●6-inch LCD panel employed.
●HD-SDI or YPbPr analog input supported
●17 types of video formats supported
●Accuracy and chroma adjustment
●Cursor display
●Tally signal 2-channel input supported
●Field frequency rate of 60 Hz or 60/1.001 automatically identifiable
●Input channel CRCC error detection (for SDI inputs)
●Lightweight and compact in size (3U half-size)
●DC12V input (10V to 18V supported, 2A (Max.) , round type camera connector 4-pin)
●Connectable to a camera battery
Ken
Ken@andcut.com
Hi! If not sold. I am interested.
Does it have anamorphic ratio and can i watch this proccessed (unsquizeed) signal on other monitor?
