Ryan Sims
Has anyone heard of what the sensitive of the RED sensor will be in the range of ASA(ISO)? How fast of lens do I need to buy? How big of a lighting package will I need?
As for size of lighting package, it would be the same as shooting on film, based on the ASA rating of your choice. I have almost been caught out shooting with a Viper (film stream), by the amount of light required! Any one who says you need less light than for film has clearly not worked with both mediums.
If a video camera and a certain film has the same ASA rating, then by definition they require the same amount of light to get the same (good) exposure. Some people may think that video requires less light because you can use gain in video but not in film.
I wonder if all lux/ASA ratiings and metering will be sans red camera control? In other words all f stop and external filter no in camera exposure step control.
They have yet to specify if the gain can be adjusted on the chip thus changing the sensitivity. My hunch is that it cannot as this might simplify the electronics and lead to a lower noise floor (would it? I've been reading up on CCD's and assuming that the Mysterium is a "frame transfer" CCD, but I can't tell if this is completely true.) But since the camera appears to have a deep toe, bringing up a dark image in post should be more possible. In comparison to bumping the gain, this means more posturization but less noise. Pick your poison.
It doesn't seem from the renderings and photos that the camera has internal ND filters. Its possible that the only way to control exposure in camera will be shutter and frame rate. So you might want to look into buying some ND's and a matte box. Start thinking of this thing like its an 435 not and HVX.
Anyways how often when shooting film do we really want to be over 250 ASA, 200 to 320 on digital with almost no noise is like butter.
Ian Bloom
