[SOLD] Arri Zeiss Super Speeds 18, 25, 35, 50, 85 T1.3 - NOT B-SPEED - Real Supers
Status
Not open for further replies.
Joshua Binder
Wiesbaden, DE
www.iamjoshbinder.com
Full Set of Super Speeds with Pelican Case.
Located in NYC so if you want to come check them out let me know if you are local.
I will be in LA Thursday through Monday for Christmas so if anyone is seriously interested I will bring them with me.
These lenses were being used so they are extremely well maintained.
Depending on your point of view these are considered either MkII Version 1 or Mk I - There seems to be a lot of confusion because people are selling OLD B-Speed lenses (which came with Arri B-Mount and the Triangular Iris) as Mk I Super speeds. These are TRUE MKI or MKII version I
Optically they are identical to the MkII with the extended Focus rotation.
THEY ARE NOT B-SPEEDS
These are TRUE T1.3 / f1.2 Super 35 MM Super Speeds
They are the models with the focus rotation that goes a bit over 180 degree
So both FEET and METERS are along the entire circumference of the lens and on one side of the Focus Gear
18mm T1.3
25mm T1.3
35mm T1.3
35mm T1.3
50mm T1.3
85mm T1.3
Often sure speeds because of their age have pretty crazy flaring because of worn coatings. This set is in pretty immaculate shape and all of the lenses have very nicely controlled flaring, especially for a set of old Speeds.
$35,000
Thanks!
josh@iamjoshbinder.com
Status
